ok so this is my first post on this site and my first attempt to build my own computer. i think these parts will work but i want to make sure.. also if any1 has any ideas as to how i could make it better let me know, please and thank you. also i have a general idea on how to install a water cooling system but can't find anywhere to get the system for a decent price. i'm looking to cool my cpu and gpu but everything i find only is a cpu cooler. am i just dumb or is it really that hard to find a video card block?
Approximate Purchase Date: this week or as soon as I figure out my whole build
Budget Range: $1,200
System Usage from Most to Least Important: gaming, surfing the internet, watching hulu/youtube
Parts Not Required: mouse, monitor (Resolution:1600 x 900), speakers
Preferred Website(s) for Parts: newegg.com (doesn't really matter)
Country: USA (Hawaii)
Overclocking: yes, but not until I get a water cooling system which will be later
SLI or Crossfire: No
Parts I'm looking at so far:
NZXT Phantom 410 CA-PH410-B1 White Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146087
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support FPB Video ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
Turtle Beach Audio Advantage Micro II Virtual 5.1 Surround Channels USB Interface Analog & Digital Audio Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16829118007
[strike]APEVIA ATX-AQ700W-BK 700W ATX12V / EPS12V SLI Ready CrossFire Ready Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817148040 [/strike]
(changed as a result of comment) CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
GIGABYTE GA-Z68AP-D3(R2.0) LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128538
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
LG DVD Burner Black SATA Model GH24NS70 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136236
total: $1,116.90
total: $1,116.90
