Tom's Hardware > Forum > Digital Camera > Digital Camera General > small camera with very low shutter lag
Forum Digital Camera : Digital Camera General - small camera with very low shutter lag
Archived from groups: rec.photo.digital (More info?)
Hello,
I am looking for an ultra-portable camera with a very low shutter lag
to take pictures of children. At least 4MP and not too expensive
(<$300). Could you recommend anything?
Thank you!
Elana
Sponsored Links
elanamig@gmail.com writes:
No. Especially if you're in the US, or else I'd suggest some of the
Ricoh Caplio models that are not sold here. Otherwise your best bet
is to ignore the marketing hype about megapixels and get either a
fixed focus Fuji (no AF lag) or else get a video camera.
Reply to Anonymous
I find most of the Kodak series to have acceptably short lag.
<elanamig@gmail.com> wrote in message
news:1116970738.330865.109700@f14g2000cwb.googlegroups.com...
> Hello,
> Thank you!
> Elana
Reply to Anonymous
elanamig@gmail.com wrote:
> Hello,
> Thank you!
> Elana
Well, nothing spectacular - and almost all cameras will hunt a bit in
light that's too low for them.
Look at the Sony DSC-S90 (4 Mpixels, US$260), the Casio EX-Z55 (5
Mpixels, US$270, my favorite), the Canon SD300 (4 Mpixels, US$275) and
the Fujifilm F-10 (6 Mpixels, US$325 - but it's VERY fast). Stretch
your price a little bit more and there's the Canon SD500 (7 Mpixels,
US$500).
Good Luck!
ECM
Reply to ECM
This camera has a reputation for low shutter lag (with the right type of
memory card):
http://www.dpreview.com/reviews/sp [...] sl400r.asp
Don <www.donwiss.com> (e-mail link at home page bottom).
Reply to Anonymous
<elanamig@gmail.com> wrote:
> Hello,
Get a camera with manual focus, and adjust for the distance between you
and the subject before shooting, rather than waiting for the camera to
hunt.
You might be able to find a decent used Oly c-5050z, which is great for
that sort of thing.
Reply to Anonymous
Pentax Optio S - tiny, short shutter lag. May still be short of 4 MP
in latest version.
Reply to Anonymous
> Hello,
> Thank you!
> Elana
Unfortunately, low price and low shutter lag don't go together. There
are some things you can do to minimize the delay, however. One thing is
to provide adequate ambient light. This allows faster shutter speeds,
smaller apertures, and can stop motion, and allow greater depth of
field, so that focus isn't as critical. Get close, use flash, and
anticipate. Failing that, save for a DSLR....
Ron Hunter rphunter@charter.net
Reply to Anonymous
> memory card):
Shutter lag and memory cards are unrelated. They can affect 'shot to
shot' time, but not shutter lag.
Reply to Anonymous
Ron Hunter wrote:
>> memory card):
Also, I wonder if the OP really means startup time.
Paul Furman
http://www.edgehill.net/1
san francisco native plants
Reply to Anonymous
> memory card):
It does have low shutter lag, but with a fast enough memory card
it can take sustained pictures until the card is full. The bulkier
Kyocera Finecam M410R (uses AA batteries, has a 10x zoom and a
fairly high-res EVF) can also take sustained pictures, but I believe
that unlike the sl400r, its autofocus continues to operate as the
pictures are taken.
Reply to Anonymous
>Hello,
>Thank you!
>Elana
Elana,
I use the manual mode on my digital P&S to solve the fast moving
children problem. The depth of field on digital P&S cameras is quite
large and if the camera has the ability to manually focus you can pick
an intermediate focus point and get a large region of the photograph
in focus at any one time (this assumes that you are not using the
telephoto region of the zoom lens and that you have reasonable light
levels). It can be quite effective, but does require some setup time.
My camera has a custom setting that allows me to save this setting.
The custom mode is on the same dial as the auto/Av/portrait/night/etc.
modes.
You might see if a friend's camera has this capability and experiment
before buying. My wife recently bought a used Canon G3 camera that has
4MP and two custom settings. We have one custom mode set for the
"grandkids".
The single setting on my camera is used in the same manner.
Regards,
Roger
Reply to Roger
There are 952 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
