R Raskval Distinguished Feb 10, 2012 6 0 18,510 Feb 10, 2012 #1 best replacement for soprano rs case? (Mid tower) i have a ssd i recently installed and it just wont fit . need a good case worth keeping for 3-5 years. have about 250$ to invest (USD) can go into further detail if needed. want to be to the point
g-unit1111 Titan Moderator Jul 27, 2011 42,545 823 104,940 Feb 10, 2012 #2 You can actually get a really excellent one for 1/2 the cost. Your SSD should have come with a mounting bracket but you can always buy one. Try one of these: - NZXT Phantom: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068 - Corsair Carbide 500R: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010 - Fractal Design Arc MIDI: http://www.newegg.com/Product/Product.aspx?Item=N82E16811352007 Upvote 0 Downvote
