Sign-in / Sign-up
Solved
Dust Filter for 230mm case fans?
  • Power Supplies
  • Filter
  • Rosewill
  • Cases
  • Thor
  • Components
  • Product
Last response: in Components
May 29, 2012 4:15:48 AM
My plan...
Rosewill THOR V2 Case
BitFenix Spectre Pro 230mm Fans (1 Front intake & 1 Side intake)
http://www.frozencpu.com/products/14441/fan-931/BitFeni...
Any suggestions on dust filter options?
More about : dust filter 230mm case fans
a b ) Power supply
May 29, 2012 8:24:12 AM
Pair of your mothers old tights/pantyhose or whatever you call them in your country.
m
l
a c 105 ) Power supply
May 29, 2012 8:53:21 AM
Yup, afaik there aren't any filters for 230mm fans so its modding time :)
Moto
m
l
Best solution
July 23, 2012 3:49:16 AM
justsumguy_22 said:
My plan...
I am in a same situation and there are no 230 mm fan dust filter which I think it is a loss for fan dust manufacturer and yes it would require modding.
At first I thought I may choose 2X Silverstone SST-FF142B 140mm x2 Fan Filter with Magnet for 320mm x 155mm fans or vents (Black) and see what I can do with this.
But it might be easier if I check out Air vent filter and get something really light and thin, cut around a 230 mm fan platter and nip tuck between the case and the fan guard grid.
To test prior doing the work, I would try to cover the fan with the air vent fabric and see if the air flow is suitable because remember the 230 mm is only 900 RPM ~10%
August 11, 2012 6:19:18 AM
Best answer selected by justsumguy_22.
m
l
