Thanks for looking, finalizing my build now to start buying the parts this week.
Approximate Purchase Date: This week
Budget Range: ~1000
System Usage from Most to Least Important: Gaming , School Work/Coding, Multimedia
Preferred Website(s) for Parts: Driving to microcenter next weekend to pick up a mobo/cpu combo, so there and newegg prefered
Country: USA
Overclocking: Yes
SLI or Crossfire: Probably not
Monitor Resolution: 1920x1080
GPU - EVGA Superclocked GTX 580 - The one component I have already purchased, got a super deal from a friend, $370, batman edition.. not that I give a rip about batman but that means its only been used for about 4 or 5 months.
Okay so thoughts/questions:
1. When I first started planning this build I was thinking going SLI all the way.. but based on some advice I got on here I think it probably makes more sense to just go single gpu... Im only gaming on one monitor and only at 1080p. I think the 580 will last me pretty good for a year or two, and then I can sell it and get another higher end single gpu... thoughts?
2. Okay on the motherboard Im lost.. right now im leaning towards $70 - ASUS P8Z68-V LX LGA 1155 Z68 ATX Intel Motherboard, based on the price and the brand it seems like a good deal (puts the total build at $1032, which is nice). That would lock me into single gpu though as its 16x/4x. I'm not opposed to spending $30 more to get a gigabyte board with 16x/8x, but is it worth it?
3. Does everything look compatible... silly question I know, but having never done this before I get nervous about the memory matching the board and everything fitting in the case.
4. Only listed a SSD as I have a 1TB NAS and a couple small sata drives sitting around if I really need them. But I doubt I will use more that 120gb.
Any additional thoughts are appreciated, if you see something that could be improved please let me know. Going to start ordering the newegg parts in the next couple days.
Budget Range: ~1000
Country: USA
Overclocking: Yes
Thank you!
Have you looked at the HAF 912? Its a pretty large mid tower case and i know youll have room for that GTX 580
