Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Need Advice on 1st Build
Forum Systems : New Build Need Advice on 1st Build
I am focusing on gaming primarily Battlefield 3, SWTOR, Skyrim at 60FPS on 1080p resolution. I also download and stream movies/t.v shows often but I do not keep them on my current laptop after viewing them. I would be interested in burning blu-ray movies and dvd's.
My max budget for this PC $1,500 roughly any ideas on where I could save money and still have peak performance I am all ears. However, if no one can find where I can save some money I guess I will be stuck paying $1,868.91. I am looking to buy in the next month or two I was debating getting the pieces of hardware over time instead of buying all at once. Then I thought what if I receive a piece of hardware and its DOA and I don't test it for months before I build my PC then I will no longer be able to return it so I am thinking I will have to wait and spend my money lump sum.
I am currently looking at hardware from newegg.com because they have such an expansive selection and easy to navigate website. I have found cheaper prices on Amazon.com for some of the hardware. I would however more than likely buy all hardware from one site.
CPU: i7 2600K
http://www.newegg.com/Product/Prod [...] 6819115070
MOBO: ASUS P8Z68-V PRO/GEN3
http://www.newegg.com/Product/Prod [...] 6813131790
GPU: Sapphire Radeon HD 7970
http://www.newegg.com/Product/Prod [...] 6814102961
RAM: G.SKILL Ripjaws X Series (2x4GB) DDR3 8GB (1600)
http://www.newegg.com/Product/Prod [...] 6820231445
SSD: OCZ Vertex 3 120 GB SATA III
http://www.newegg.com/Product/Prod [...] 6820227706
HDD: Western Digital Caviar Black 1.5TB 7200 RPM 64MB Cache
http://www.newegg.com/Product/Prod [...] 6822136793
PSU: SeaSonic Platinum 860W
http://www.newegg.com/Product/Prod [...] 6817151111
Optical Drive: Samsung Black 12X BD-ROM
http://www.newegg.com/Product/Prod [...] 6827151232
Case: Corsair Special Edition White Graphite Series 600T
http://www.newegg.com/Product/Prod [...] 6811139005
OS: Windows 7 Home Professional 64-bit OEM
http://www.newegg.com/Product/Prod [...] 6832116986
I would like to overclock and I have no experience with it or building a PC, but I am sure I can figure it out I have already been looking into it. I am not sure if I should look into downgrading GPU's and running SLI/Crossfire to achieve the same performance as the 7970 for a cheaper price if that is possible.
I have no idea if I should look into a heatsink for my CPU, I have no experience with water cooling and how complicated it is and is it worth doing, I am looking at using my 120hz 55in led 1080p t.v as a monitor for this system does anyone recommend me not doing this I was going to use the HDMI input on my tv.
Total Price: $1,868.91 USD kind of more than I wanted to spend but I think this has everything I would need other than heatsink/fans/watercooler and anything else I may have over looked.
Message edited by jemcglot on 02-12-2012 at 08:54:04 AM
Reply to jemcglot
Premium graphics cards are not worth the price IMO .
My choice would be a 7950 . Probably the gigabyte "windforce" model with 3 fans
All Z68 motherboards will perform identically at stock speeds . You can spend way less and miss a tiny fraction of overclocking [ if anything ]
ASRock Z68 Extreme3 Gen3 $122
http://www.newegg.com/Product/Prod [...] 6813157271
Your psu is also a premium item . It will run more efficiently but the difference is so small you will never notice .
You could use the Corsair 650 TX , or 750 TX if you might add a second graphics card . Not likely to need that b4 the rest of the machine needs replacing tho
Cases are a matter of personal taste ....... but will a white case really go with your other components?
Message edited by Outlander_04 on 02-12-2012 at 08:59:55 AM
Reply to Outlander_04
For gaming change the CPU with 2500k.
Change the mobo with that what Outlander_04 recomended you or this ASUS P8Z68-V/GEN3 http://www.newegg.com/Product/Prod [...] 6813131792
Power supply 80+bronze modular can keep two 7970 in the future CORSAIR Enthusiast Series TX850M 850W http://www.newegg.com/Product/Prod [...] 6817139029 120$ after rebates.
Message edited by sosofm on 02-12-2012 at 09:29:56 AM
------------------------------ i7 2600 , AsRock P67 Extreme 6 ,2x4GB Corsair Vengeance 1600 , MSI 6950 2GB , HDD WD 640 AAKS , Corsair 620HX 620W , CPU cooler Zalman CNPS10X Performa , CoolerMaster 912, Philips Led 22"
Reply to sosofm
I would sugest to have a premium psu as it is the veins of ur pc.
as psu looses its efficientcy over time.
a 80+ silver or gold 850 w would do if sli/crossfire and 1000 w if every thing over clock if im corecct.
if wrong corect me
Reply to serialkiller
if wrong corect me
OK then
http://www.realhardtechx.com/index [...] age362.htm
a comp wth a single 7970 NEEDS a decent 550 watt psu .
650 watt is reasonable head room
While a gold or silver rated psu is a better quality unit than a bronze rated unit its very hard to justify the cost when 1/ a bronze rated unit will work perfectly well and 2/ you are trying to save money
Drop the core I7 to a Core i5 2600K
Runs the same for all current gaming and most in the works, odds are if you are going to need faster than that by the time you will the I7 will be as equally outdated.
Reply to Maxor1
There are 2084 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$650 dollar budget 'gaming' rig. Can you help?
By geofelt, 1 hour ago:
To answer your question, an aftermarket cpu cooler is not necessary with a 2100. For $5...
Best offers
Top experts
