I've recently completed my first computer build. I double checked every connexion, followed every manual indications, checked numerous online tutorials and an hour ago i felt like i was done!
...but now, ive hooked up the build to my monitor, keyboard and mouse.... turns out, the power turns on, the mouse seems reactive, the fans are spinning, including those that are plugged into the mobo and not directly into the psu.
I can open my dvd drive, i can use all the front panel connections, no problem.
BUT, my 19'' monitor still tells me ''No signal''
Anyone has any advice on this? I've scoured the net for an hour or so, but there seems to be so many different ways this could have went wrong, im not sure in which order to check. I dont have access to a second monitor sadly to compare, but it worked fine on another computer a month ago. I've just spent the last 8 hours on it, carefully plugging everything in place and doublechecking, so now im kinda stumped, and mildly frustrated =P
Thanks!
__________________________________________________
CPU: Intel i5 2500k +Hyper212+ cooler
Mobo-Gigabyte z68 UD3H-B3 (Monitor is plugged into mobo, since the GPU's ports were not standard format for it.)
RAM:Corsair Vengeance 2x4GB (8GB)
PSU: XFX 850W
GPU: Gigabyte GTX 570
Thanks!
PSU: XFX 850W
