G
Guest
Guest
Hey all,
I've been posting here alot wondering about my prebuilt gateway, this is the one I have:
http://www.amazon.com/Gateway-FX6860-UR20P-Gaming-Desktop-Black/dp/B0050JSJU4
Well today some odd things started happening in HWmonitor, I was monitoring my temperatures in idle, the cpu is an I7-2600 sandy bridge 3.4 ghz, and normally they sit around 35-38 and don't move maybe but 1-2 degrees in idle every once in awhile.
However, now the core temps are constantly changing in idle, and core 0 spiked from 38-47c, then back down to 38 instantly, and the package watt consumption is constantly changing, ranging from 5.42W-26.63W when I was doing a virus scan, which found nothing.
Even as I type this now, the temps are fluctuating, but between 36-39c and some cores even hitting 40c, with just firefox open, I don't know what's going on, since it's never done this before, and I downloaded coretemp too, and the same thing happens there, any ideas?
Thanks.
Thanks.
