Help me build a Desktop~
I want to build a new PC.
Ummm,what do u think about the components that i want 2 use?
MOTHERBOARD : Asus P8Z68 DELUXE/GEN3
PROCESSOR : intel i5 2500K
RAM : 4GB CORSAIR DOMINATOR GT
GRAPHIC CARD : Asus nVidia GTX560 Ti
MONITOR : ViewSonic 22 inch VX2268WM 3D LCD Monitor
HARD DRIVE : INTEL 320 SERIES 120GB 2.5' SATA SSD
Umm,if there is any wrong with my builds please tell me.
Thanks.
4 answers Last reply
More about help build desktop
  1. You can buy cheaper without loosing quality and performance.
    Motherboard : ASUS P8Z68-V/GEN3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131792 180$
    RAM : CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186 50$
    Your buils looks good.
  2. Do you want to hop over into the Systems > New Build section of the forums?
    If you fill out the form in *How To Ask For New Build Advice* you'll answer all the standard questions that help things get started.
    Thanks.
    Your choice of components are okay I advised you to have at least 8 GB of DDR3 RAM
    How about the PSU? Get a PSU of at least 700 watts of power or higher.
  4. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
Build Systems Product
