So i finally received my first computer, a prebuilt iBuyPower that i got shipped to the States and had someone bring to Canada for me. I know, I know, it's much cheaper to build it yourself but tbh I just didn't have the time or the know-how to do it and when I compared the two, iBuyPower wasn't that much more expensive. So anyways I finally go to set it up and plug everything in for the first time and......... nothing. Everything turns on, all my led's , all the fans and the liquid cooling, everything runs. I get a signal to my monitor but after about 10 seconds or so I get a beep and all the led's on the motherboard shut off. As I write this im reading through my manual trying to troubleshoot as well. I just thought i would post in here and ask for some help.
My build is :
i7-2600k
asrock fatality professional gen 3 z68 mobo
8 gigs (4x2) corsair vengeance RAM
amd hd HIS 7970
coolermaster silent pro 1000w
Before you guys laugh i learnt a lot more about what i needed mobo/processor wise(2500k) and the ridiculous power supply my buddy talked me into after I ordered it. But if you can help me out it would be greatly appreciated.
Also, wasnt sure if I should post this in the systems section or the motherboard.
Thanks again
My build is :
i7-2600k
amd hd HIS 7970
Thanks again
