Hello,
1) First issue is cooling, I have 2 GTX 285s running on an Asus P6T MOBO, it's a dumb design as the GPUs are side by side and just cook each other (GPU1 @58c and GPU2 @ 49c and that's doing nothing and after a good cleaning). I need to get better cooling, I need to 4 pin adjustable 80s and one 120 and a controller I'm hoping quality fans will help a lot in itself over stock crap. I have a Lian-Li PC-B25B (mid tower)
I'm also looking for advice on a CPU cooler as sad to say I still have the generic CPU cooler that Intel provided I have an I7-920, I'm hoping that will also lower the TEMP inside the box.
I'm not really into OC I'm a professional day trader. Hence, I need a stable machine but I do like to play COD here and there.
My current Mem is 6 gigs of and 6 more on order Corsair CMZ6GX3M3A1600C8 (will that suffice?) I just recently started running it at XMP 1600 (Do you think a mem cooler is required for 1600?)
2) Next Prob is I need to add more screens. I currently only have my 50" plasma TV and Dell 21" which is not enough I think I need to add at least 2 more monitors. Will my current setup handle it?
3) Currently running Vista 64 though about to upgrade to Win 7 Pro (Do you guys think professional version is adequate?) I was told that 7 handels mem more efficiently and is a better os by traders tech support.
P.S. I keep having serious dust issues, my brother had a similar case (which is why I went with this brand) and just seems like his internals are crystal clean as mine look like they work in a coal mine, would also love to hear any advice on that issue or if a new frame would be required. I do have a good PSU it's an Enermax Revolution 85+
Also, does anyone have any tips on good monitor mounts?
I'd be grateful if you had any advice about the problems described above.
Thanks Very much for any advice,
Sebastian
Sebastian
