Help: CASE/CHASIS for Asus Rampage IV Extreme
Good day everyone! I would like to ask some help to find any CASE/CHASIS that would fit my Asus Rampage IV Extreme. Thanks in advance! :bounce:
PS: Here's my rig
Ram: Corsair 16GB 1600 Quad Channel Kit
Cooler : Corsair H100
GPU: Asus GTX 680 Direct CU II OC
Mobo: Asus Rampage IV Extreme
CPU: i7 3930K
PSU: SilverStone Stider Gold 850Watts
24 answers Last reply
More about help case chasis asus rampage extreme
  1. Any case that fits micro-Atx and upwards will do, whats the rest of the hardware?
    **Edit sorry, my googling gave me results for the Gene, which is the M-Atx plate, my bad :)
    Thanks Jack, good catch mate :)
    Moto
  2. @Motopsychojdn
    I read a lot of rumors people find it difficult to find a chasis/case that would fit E-ATX Motherboards.
    BTW Here's my rig:
    CPU: i7 3930K
  3. EATX is the same height as ATX (30.5), but a little wider (27.x instead of 24.x). Not counting openings for cable management, almost any ATX case should fit.
    However you can easily check manufacturer specifications to make sure even the cable management openings aren't covered by an EATX board. Just look into some cases you like in the first place.
    Some good cases:
    Corsair 800D
    NZXT Phantom
    NZXT Switch 810
    Fractal Design Define XL
    BitFenix Colossus
    Some LianLi and Silverstone cases are good options, too.
  4. I gotta argue with Moto above as a mini-ATX chassis is certainly not going to fit an EATX MoBo.....An ATX chassis won't fit an ATX board, you need an EATX chassis.
    How much ya wanna spend ?
    $290 Thermaltake Level 10 GT Snow
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811133192
    $255 Corsair 800D
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001
    $185 Antec P193
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129176
    $180 Coolermaster HAF-X
  5. Dragon rider will hold an E-Atx as well,
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811108376
    White edition also available
    Moto
  6. thanks for the replies guys! I already bought NZXT Phantom full tower case. :)
  7. Cool, enjoy it, and we want a build log with pics from you ok?
    and keep those cables tidy :)
    Moto
  8. @joshua,phantom is one of my favorite case,moto is a cable management geek so keep it tidy :)
    and i won't suggest level 10 GT because-
    recently saw it on a nearby shop and the things that i noticed:
    pros-
    great build quality and looks,the case is sturdy and looks bad as hell.
    color changer fans look cool and suck plenty of air.
    good cable management and can fit large graphic card(s)
    roomy enough to fit a high end *air cooled* system.
    hot swap drives,headphone holder and other stuff is common now days but still looks cool.
    pros-
    expensive and not worth a $300 price tag(you can it cheaper may be $290 or so)
    looks big,very heavy, but still not enough room to fit a heavy watercooling loop.the best you can do without cutting your case is-
    there are a lot of other cases that are cheaper and provide similar(or better) features.
    side window is too small to show off things.
    bottom line don't get level 10 GT unless it's a personal preference because you can get the same features for less.
    good luck with your choice ;)
  9. +1, I am the C.management monster here on Toms :)
    and if you ever bought a level ten, it should only be the Aluminium proper one, not the plastic GT,
    I'm just waiting for some kind person to donate me one to mod hehe
    Are you listening Thermaltake????
    Moto
  10. yeah if i meet someone from thermaltake then don't worry i am gonna ask them to send one for our experiments lol.
  11. Me, a TTL10 and watercooling?
    you know thats a recipe for epic win :)
    Moto
  12. hey can you tell me one thing,is it possible to fit a 360mm and at least a 120mm rad in level 10 gt?
  13. 120's go anywhere,
    you should manage a 360 up top with the first portion inside the optical drive cage, I can't find any pics on the nets where anyones done it though
    Moto
  14. yeah but if we do some modding then we can put rads out side of the case but rads hanging out of case look ugly.still for watercooling,800D,TJ07,TJ11 and Swtich are best IMO.
  15. Modding is always an option with me man, you should know that :)
    I tend not to look at a case as a finished item, more as a baseline for me to start from
    Moto
  16. yes that's why you transformed your dragon rider into such a beast!
  17. I once modded a kitchen into the Pc but the Cable management was a nightmare so I took it back out, shame really the fridge and oven bits were great :P
    after kitchen removal,
    Moto
  18. ^truly bada$$!
  19. It may be evolving further soon, we may be moving the Pc's into a different room so I have plans for a centralised chiller box/res feeding both of our Pc's loops :)
    means a W/c loop for the Gf on my pocket ofc but I don't mind hehe
    Moto
  20. @motopsychojdn
    here's my build log with pics! LOL sorry for the crappy image gotta find a good camera soon
    https://www.facebook.com/media/set/?set=a.4082828678994.2170652.1530900626&type=3&l=3174f62dfe
  21. @hellfire24
    Actually I was looking for a Cosmos II or TJ11 as my case but they're both out of stock. I might sell this phantom full tower case if Cosmos II will be available hehe
  22. Anyone else on tom's got an FB?
  23. I Don't do failbook.
    @Op nice progress shots man, looks like I'm not the only one to measure the DCII with a tape and go 'Dayumm' :P
    maybe post a build log on here with some text for the pics, and then some finished pics in the members gallery?
    Moto
  24. joshua_jc08 said:
    @hellfire24
    no need bro,phantom is pretty cool case.
Power Supplies Asus Cases Rampage Components Product
