Hi,
This is the first time i'm building my new system
below is the configuration:
cooler master extreme plus 460W psu
Intel Dh67cl Motherboard
Intel 3.3 Ghz core i5 2500K
Seagate Barracuda 1TB SATA 6.0Gb/s
Hp Dvd1260i CD/Dvd Burner
Crosair 4GB 1333 DDR3 RAM
Unknowingly, I screwed the motherboard directly to the case without using standoffs. However, since it was hard to put screws into all the holes, i didn't attemt to screw all the holes. (no physical damage to mobo).
When I power on the system, smps fan doesn't start. mobo light is on. no beeps. Rear panel fan also doesn't start.
This is a new system.
is there a chance that I've shorted the mobo or any chances of damage to mobo ?
Thanks
Thanks
