Problem with formatting OS!
Ok i had an error on a logon process that cant be fixed..so i decided to Reinstall my OS!
So here is the problem...
I did everything fine until this message appears about Damaged hard disk...
So I used my Google and found a solution...The solution Is when it says to press F6 and F2 i press F6 and it says that i need to put a floppy with RAID drivers..so here is the problems how im a suposed to put drivers in my floppy when there is jus max 2MB of space in one floppy...and how can i find what RAID drivers i need?
6 answers Last reply
More about problem formatting
  1. A usb drive or use a cdr or dvdr and put them on those as an alternative to the floppy.
  2. what operating system , what motherboard?
    do you actually have a RAID ?
    Sorry ,but I dont get it...how can I put It alternative to the floppy?? Please helP!
    I have Windows XP professional,A8V Series ASUS motherboard...you got my confused with that RAID question...now i dont know...how can i find out...please help!
  5. Reboot
    Enter BIOS [ start up] , usually by hitting the DEL key but it could also be another key . Instructions will be on the black and white txt screen .
    Find out how many hard drives are installed . If there is only 1 then change the setting so the hard drive is set to "native IDE " [instead of AHCI . It may even be so old that the hard drive is listed as SCSI
    Native IDE could be called something similar , but definitely with IDE
    After those changes windows XP will install without further problems
  6. I have 1 ,but how can i change those settings ,and where can i find those cofingurations?? is it main,or advancded (in BIOS)
Homebuilt Floppy Disk Formatting Drivers Systems
