Solved
Need advice on case for new build
Hey guys I am somewhat of a budget and I need a case for my new build. It needs to be able to accommodate a large GPU. Preferably I would like to spend around $50 as I am already over budget by quite a bit.. I would like something with an acrylic side window and I would like it to include at least 2 fans. I know its a tall order to fill, but I am excited to see what you guys suggest! Thanks in advance.
5 answers Last reply Best Answer
More about need advice case build
  1. Nothing fits those criteria for 50
  2. Well I was looking at cooler master elite 430 which is less than 50 but only one case fan..are you sure there aren't ANY?
  3. Best answer
  4. If you can live without a window, then the NZXT Source 210 elite is an awesome case for the price.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146078
    With window:
    NZXT M59 - 001BK
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
  5. Best answer selected by Matt1990.
Power Supplies Cases New Build Components Product
