How to set cpu Fan speed to 50% automatically when i run the SpeedFan 4.46
How to set cpu Fan speed to 50% automatically when i run the SpeedFan 4.46 application. Previously i used "MSI dual core Center" application. it run ok in quiet speed but when i just do little web browsing, the fan speed exeed and it make so loud noise.
i installed SpeedFan 4.46 it stated my fan speed01 is at 100% but i can changed to 50%. what i need is to set cpu Fan speed to 50% permenently and automatically on window startup and the speed should remain same until i shut down my pc.
please help me guyz.
Window 7 32bit, 2GB Ram, core 2 duo 2.4ghz
motherboad: MSI (MS-7529)
2 answers Last reply
More about speed automatically speedfan
  1. Hello seelanyoyo;
    You probably can't do that with your MSI motherboard.
    That's especially true if your CPU is overheating - that's going to make the fan run full speed.
    What CPU temps are you getting?
  2. statement based on SpeedFan :
    Temp1: 28C
    Temp2: -128C
    Temp3: 40C
    HD0: 45C
    GPU: 60C
    Core 0: 31C
    Core1: 30C
Speedfan CPUs Components
