Solved
What power supply watt for gtx 670 sli
I'm running an i5 2500k, 8gb ram, on a asus z77 pro. Someone i work with told me I'm going to need at least 1000w, seems kind of high... if so please give me your suggestions. Thanks
11 answers Last reply Best Answer
More about what power supply watt
  1. For 2 gtx 670's in SLI, you are looking at a quality 650W psu.
    http://www.guru3d.com/article/geforce-gtx-670-2-and-3way-sli-review/4
  2. It's a lot high.
    What else are you going to power with the PSU? Anything besides the usual high performance gaming stuff?
  3. WR2 said:
    It's a lot high.
    Well a hdd,sdd, a evo heatsink, cd/DVD drive, and about 6 fans... Any recommendations on a good psu?
    Thanks for the link... Looks like 1000w would be a crazy overkill. Thanks!
  5. I recommend a 750W, just in case you want another one for triple sli.
    Have you decided a budget for a power supply?
    Yeah anywhere from $160 and down
  7. Best answer
  8. amuffin said:
    Wow, so why does it only say 750w on the psu? Thanks for the link... Will I run into any problems if I ever decide to overclock with this psu?
  9. Nope! Corsair power supplies are made by Seasonic. They make they best quality units!
    Aw that's great man... I'm gonna go buy this now... Thanks for the help!
  11. Best answer selected by Hint172.
Power Supplies Components Product
