Sign-in / Sign-up
Solved
I5 2500k temp problem/advice/help
  • CPUs
  • Intel i5
Last response: in CPUs
June 2, 2012 7:03:45 AM
Hey,
when i have heroes of newerth running my cpu temp rose up a lot to like 60-70s and the loads are between 30-50% are the temperatures fine or its running hot? im currently using stock cpu fan the comp was build for 6-7 months.
Thanks in advance!
More about : 2500k temp problem advice
Best solution
a c 293 à CPUs
June 2, 2012 7:21:32 AM
That's within the limits, but I'm slightly worried about what it would be at 100% usage. It really shouldn't be that hot at stock at only 30-50% usage. What are your idle temps?
Just as a test, can you do a quick run with Prime 95 (Small FFTs is good enough) and tell me what the temps are? If they're as high as I think they will be, I think the cooler may not be seated very well.
Also, an aftermarket cooler would definitely help, regardless. For reference, I'm in the low 60's at 100% usage (with Prime 95) at 4.5Ghz with a Cooler Master 212 Evo.
June 2, 2012 7:50:19 AM
when it idle it usualy be mid 30s. i ran the prime test like u ask too the temp when to 80s.
ill try to seat the cpu fan again. i remember it suppose to make a click sound for each pins but 2 of them doesnt but at the back its through the hole of the motherboard tho. should i be hearing a click?
m
l
a c 293 à CPUs
June 2, 2012 7:56:39 AM
Yep, you should (be hearing the click). The Intel coolers are notorious for being difficult to get just right.
m
l
June 2, 2012 8:35:30 AM
i readjusted the cpu fan and heard four clicks from each pins.
this is my core temp readings when its idle.
Thanks btw!!
m
l
a c 293 à CPUs
June 2, 2012 8:37:47 AM
Looks fine, but what are the temps under load now?
m
l
June 2, 2012 8:48:47 AM
alright i think its fix cuz my temp drop by 10-20. ran heroes of newerth again played a game the temps are at 40-50s.
i think i just didnt place the cpu fan correctly
Thanks alot!!!
m
l
a c 293 à CPUs
June 2, 2012 8:57:41 AM
Awesome! And no problem! :D
m
l
June 2, 2012 12:41:33 PM
DJ deserves best answer so I hope this guy didn't just ask and run like so many others...
m
l
June 19, 2012 5:18:24 PM
Best answer selected by pokettomonstua.
m
l
