Here is my current build:
CX430 V2 Power Supply
NZXT Gamma Case
Asus DVD-RW
Seagate 7200RPM HDD
Intel i3-2100 using Stock Cooler
Corsair Vengeance 2 X 4GB DDR3
1 120MM Fan that came with the case
So I intended to install a 6870 into the case, and then realized there was a big noob mistake in the room.
I was reading reviews and then saw that the 6870 required two PCI-E Plugs, instead of the 1 that is required by the 6850.
Now I looked at my build and did in fact find 1 PCI-E Plug, and 3 Molex/4 Pin plugs available.
The CX430 should be able to easily and safely power a 6870 (AFAIK), so the issue is the connections.
With 3 Molex Plugs available, I could purchase this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812887001
Is it safe and reliable to use a 4 Pin adapter like the one above?
This will leave me with One 4 Pin connection left to upgrade from the single exhaust fan
to the 2 fan system. If you have seen photos or own the NZXT Gamma, you can see that the HDD area seems to block a good amount of airflow. I would probably want to go with the highest CFM 120MM Fan for the front intake, right?
Can anyone chime in if the front HDD area blocks as much air from a front intake fan as it seems?
This seems to have a much higher CFM rating than the other fans on Newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200048
NZXT Gamma Case
Asus DVD-RW
Seagate 7200RPM HDD
