LAN v Wireless Connection
Last response: in Networking
First and most simple suggestion - try a different cable. They can cause problems sometimes, particularly if they're in a room which gets cold at night and warm in teh daytime, or if they're caught under a piece of furniture.
Thanx for that but tried a different cable and no better. Even tried old cable in laptop and run that through the router and there was nothing wrong with the connection, so it looks more likely my PC is at fault, but cannot work out why. Hate to think that i'm going to have to reinstall Windows so any advice would be appreciated.
Ask the community
