Hello all!
I've had a lot of people help out in these forums, and now I come asking another question from my new (now about 3 mo. old) build.
First of all, all aspects of the computer seem to be in order: temps (cpu, system, and gpu) are all good, fans are working quite well, the recent OC to 4.0 from the i5-2500K 3.7Ghz has been stable as lead and I have had no problems regarding heat. No bsod, no hang ups, no probs overall. Haven't even crashed yet.
However, there is a new issue: a noise emanating from the tower. It is unlike anything I have heard before from the tower, and doesn't seem natural to its function: it is a high pitched (VERY high, seems to permeate to the upper ranges of audible perception), low intensity, almost clicking scratch. The pitch does seem to vary slightly while maintaining high pitch, and the intensity also varies very slightly. I can almost describe it as the sound a chalk would normally make against a chalkboard when in use, except instantaneous, extremely low in intensity, and with no "knock". It even has what I can only describe as a metallic quality to it.
Here's the worst part of this: though the intensity of the sound is almost inaudible, the pitch is so high, it is annoying, very penetrating to the ear and the overall ambient noise. The noise is capable of being heard with almost no variation of intensity from a range of 7ft to right up inside the case. It SEEMS (as much as I have been able to deduce, so take this with a grain of salt) that the noise emanates from the BACK half of the case (cutting the case in the transverse plane), so I can only assume this isn't HDD related. But again, difficult to isolate considering the pitch. It seems even harder to pinpoint the closer I seem to get to the case.
The noise seems to have no discernible pattern, "click-scratching" at random without real relation to load, temp, or current activity. "Clicks" are sometimes not there, sometimes showing up once very 2 or 3 seconds, and anywhere in between.
One last note: I noticed this noise only after first booting up Metro 2033, bought bout 2 weeks ago. No idea if that is relevant.
Thanks for the help!
