XFX 4670hd - what is the minimum power requirements ?
Hello guys ,
I am planning to buy a xfx 4670hd . But I doubt that whether it will work on my PC with a 500w PSU .
My 500 W psu provides 16amps in 12 V rail . Will 4670 hd work in my PC ?
Or is there any better graphics card that will run on my PC ?
Please suggest some better graphics card which lies inside the price range of Rs.3000-Rs.4000
($50-$80)
And again my PSU is 500w which can supply only 16amps so don't suggest any graphics card that won't run in my PC .
And my monitor resolutions is 1280x720
RAM :- 3gb
Processor :- Intel core 2 duo E7500 @ 2.93 Ghz
Motherboard :- Asus p5gc-mx/1333
Thanks !
1 answer Last reply
More about 4670hd minimum power requirements
  1. That 4670 Will Run Fine Since There Is No Dedicated Power Connector On That Card, But Id Suugest Something Newer Like... http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=%206670&IsRelated=1&cm_sp=KeywordRelated-_-5670-_-%206670
Radeon Graphics Cards Power Graphics Product
