First off, hello, how are you, I am well...now on to business!
I have constructed my computer a bit over a year ago in Nov 2010 and I am now looking to upgrade my current graphics card to the HD 7970, specifically looking at...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102961
I have notice that this particular card uses PCIe 3.0, my motherboard only supports PCIe 2.0, so obviously I should upgrade, looking into this I also realized the new card is a bit larger than my current card, which fits nice and snug in my current case so I might have to upgrade that as well...
tl;dr - basically does anyone have any suggenstions on any upgrades I should go for, even those I might not need now but could use in the future
Thanks a bunch in advance!
Specs:
Case - LIAN LI Lancool PC-K62
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239
MoBo - GIGABYTE GA-X58A-UD3R
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
CPU: Intel Core i7-950
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Memory: G.SKILL PI Series 6GB (3 x 2GB) DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231335
GFX: MSI R6870-2PM2D1GD5 Radeon HD 6870 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127530
HDD1 (System/Programs) - OCZ Vertex 2 OCZSSD2-2VTXE60G 2.5" 60GB SATA II
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227550
HDD2 (Games/Storage) - Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
PSU: XFX Black Edition P1-750B-CAG9 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207003
If you need any more information please let me know, thanks again!
Specs:
