user_account_
248
Hi all just got some new Trittons AX720 and I am sure they are not giving me surround sound. I do NOT have a sound card but sure my motherboard supports 7.1. I am using it via optical cable.
Board is a ASUS z68-gen3
Thanks in advanced.
user_account_
248
There is no option on the mix amp for surround but on the hub there our lights and all our on but one and that is the dolby 5.1 mode but there is a pro logic llx mode and that is on. Do I need a sound card. I am running optical mode btw. Thanks for reply
user_account_
248
I have read the instruction manual a million times there is no button to active 5.1 I think I need a sound card. Thanks for help though.
optical cable
Theres the problem. Optical can only transmit 5.1 if Dolby/DTS is used. And most PC audio does NOT use either of these formats. As such, you need a soundcard to handle the realtime encoding of uncompressed 5.1 to either Dolby or DTS in order to get 5.1 using optical.
user_account_
248
Thanks gamerk. I am looking at some Asus DS
http://www.pcworld.co.uk/gbuk/asus-xonar-ds-7-1-channel-pci-sound-card-07929963-pdt.html
and maybe get some mid range 5.1 surround sound for time being. Then save for some trittons again as I took them back and sort of realized I need a sound card. Would this sound card be enough for true 5.1 or even 7.1. Thanks again mate for you reply. :)
