2500k constant switching between idle and overclock speed
Last response: in CPUs
Related ressources:
- ForumI5 2500k 85 deg idle cpu temp?
- ForumHD 7950 fan spins up to 100% at idle
- ForumConstant BSOD, tried basically everything, very strange
- Forumcorrect Temps I5 2500K overclock
- ForumSwitching between overclock and standard BIOS settings
- Forum2500k help
- ForumIdle Chit Chat...
- Forum2500k Idle /Load Temps: Should I OC?
- ForumI5 2500k @ 4.2ghz 1.288v
- ForumI5 2500k Trying for 5Ghz
- ForumNew PC constant BSODS
- ForumDo i own the worst 2500k in the world?
- ForumI5 2500k idle temps high?
- ForumI5 2500k 4.0ghz cores 73 degrees?
- ForumI5 2500K clocks keep changing
- ForumNeed some help replacing PSU
- Forum[Solved] Case fans running high at idle
- Forum2500k & Z68 or 3570k & Z77?
- ForumI5 2500K temps
- ForumIntel i5 2500k and required cooling - please help.
- More resources
