Weird graphics problem
Hi,
I've been trying to search a solution to this problem, but haven't found one yet so I decided to try if I can find an answer here.
So... lately I've been getting this weird graphics bug in all the games I've tried. The edges of textures appear with sharp and sawblade like edges. The problem doesn't stop there... The shadows are also behaving oddly and form from either small or big squares (depending on AA). I've already checked that it's not a GPU related problem.
Here's a couple of screenshots to show how it's like in SWtOR with 16x AA:
Thanks in advance.
5 answers Last reply
More about weird graphics problem
  1. Hi and welcome , what graphics card are you using?
  2. Thanks, the gpu I'm using is MSI GTX 560 TI Twin frozr.
  3. Ok have you updated to the latest drivers from Nvidia?
    Looks like AA isnt even working in the pics , lots of jaggered lines.
    Check in your Nvidia Control panel 3D settings what you have put for AA, force the AA on to overide application and set it to the desired level. Start the game again and see if it makes any difference.
  4. Alright, thanks for the tips. I'm currently at work so I can't check the settings, but the thing is... I already tried if I had the same problem with my old gpu (8800 GTX) - and I did. So I doubt the problem is gpu related. Any other ideas what could cause this? All help is greatly appreciated.
  5. And yes, the drivers are up to date.
Nvidia Graphics
