The GTX 580 is basically a piece of crap I have come to believe. I have two, have had them for a year, and have had problems with them since the day I bought them. Opened multiple tech support tickets with the vendor (EVGA) and they never reponded to a single ticket.
Over the past year I tried everything I have seen on all the different websites (Bios Updates, Windows re-install's, every driver version there is, memtest, different ram, overvoltage, underclock the cards, SLI on, SLI off, replace the SLI Bridge, remove one card or the other, upgrade Intel Chipset software, Upgrade Intel Rapid storage software, Raid on, Raid off, remove virtually all software installed, I could go on and on. It crashes in WOW, and other games. It freezes at the Windows logo screen. It even freezes at initial cold boot sometimes. Remove the cards, put in another brand (or even another EVGA card that's not a 580) and it works perfectly.
Best I can tell, it's an incompatibility with the Motherboard brand and/or Bios settings. My entire family is aware of this, they use EVGA cards too (not 580's) and none have problems. But the problems I have make them ALL leary of ever buying another NVIDIA product again, as well as me. Google the problem, some sites have over 200 PAGES of people screwing with the cards and almost all can't fix the issue. They either RMA the card, eventually getting one that works or a new model, or else buy another brand.
It's rediculous.
Intel i7-980x 3.33GHZ 12M
Corsair Dominator 2GB 1600MHZ * 6
Asetek 570LX 240MM Watercooler
Gigabyte x58A-UD3R
Thermaltake Tough Power 1200W
Superclock EVGA Nvidia GTX 580 1.5GB PCI-E *2
Windows 7 Home Premium
120 GB Intel X25-M Sata *2
WD Velociraptor 600GB *2
