Hope its correct category. Today when I heard my pc starting up whit some high pitched sound, which happens until I restart it, so I decided to try and fix it. Plugged all out and back in, started pc but the monitor didn't received any signal. (Almost normal when I tinker around.)
But 5 hours of plugging and testing didnt helped as signal wasnt coming. I tested the integrated graphic and it didnt worked either. My ram went crazy more then usual. (thre beeps) other monitor with different cable didnt worked either.
I am wondering where could the problem lie? It happened before but I usually fixed it in 3 hours tops. All worked normal the previous run of course. I took out cmos battery after I read couple of similar problems, but still all the same. Which cables do I need to focus on to replug until it works?
I suspect bad motherboard? Since I had all those problems before. (its Intel)
