Alright, so I have posted about this problem three separate times over the past month on here, and I have only gotten a solution that worked temporarily and I have done everything I possible could think of to fix the problem. I am starting to get very frustrated and rather mad that one of my only remaining solutions is to buy a new gpu, which isn't something I can entirely afford right now as I am in high school and don't have any extra money to spend on this.
You can see the first thread about the problem that I made:
Basically, reinstalling win7 worked for maybe a week before problems started happening again.
Some other things that are happening:
Random and small freezes in game.
Rare but obvious artifacts one time before it said that the graphics card drivers had recovered
The random and small freezes that I mentioned happened in LoL and after about 15 minutes it completely froze and restarted.
I also have had 2 or 3 random crashes or black screens in Skyrim.
What I have tried outside of what I mentioned in that thread:
I have tried several different beta/non beta drivers all the way up to the most recent beta back to 277.33. And every time I would install a new driver I would run through the proper process of using driver sweeper and such.
I have made sure that it wasn't overclocked, and I even lowered the clock speeds slightly using MSI afterburner.
I have also tried not installing the 3d drivers for it when I go through the install process for whatever that is worth.
After doing some more research, I have heard that what is happening to me right now seems to happen to a lot of other people with GTX460s and then are eventually forced to RMA or get something else. Mine is just over a year old, so I just that I am slightly lucky it lasted that long because most seemed to happen around the 6 month mark or sooner. Not saying I have given up on it, I im starting to think that it is about to completely die.
So on to the biggest points of the thread:
I would like to not have to buy a new GPU, but I will if I must. Is there any other possibilities that it could be or any other trouble shooting that I should do before buying one?
Also, what should I get for a new GPU <$250?
Thank you for any help!
For roughly the past month, I have been having what I think is problems with my Nvidia GTX460 video and audio drivers (The latest one, 285.62 ). It is rather sporadic, which is the reason I haven't felt like doing anything as serious of taking the time to reformat my HDD and reinstall win7 and all of my programs and such. But to make sure that I need to do this and that there is nothing else on top of what I have already done that I can do, let me say what has been happening and what I have done to attempt to fix it as of now.
The most basic thing that has been happening is a random black screen with one of two things happening after that:
It would go black for a several seconds and then the screen would come back and it would give me a notification saying "you graphics driver has crashed and now recovered" (or something along those lines) and sometimes instead of saying graphics driver it would be the audio driver.
The other thing that would happen would be that the screen would go black for several seconds and my monitor would show that their is no connection any more and it would keep searching its different inputs. After a short amount of time, the computer would either restart on its own, or I would have to do a force shut off. However, once it restarted, it would often freeze after I type in my password or right when windows desktop would show up the same thing would happen all over again. It would take numerous restarts to finally get into windows, and then it would give me a notification saying: "Your audio driver has crashed but now recovered" and sometimes it would even say that my pc didn't have an audio driver so it would install it. Sometimes, after numerous restarts and it still not wanting to work, I would go into safe mode which always worked 100% and after that I would either uninstall my drivers and reinstall ( which didn't always help) or just restart the computer from there.
What I have tried to do so far:
Reinstall the drivers (making sure that the old ones were completely removed)
Make sure nothing was plugged into the computer that could be causing the problem
Taking off the small oc I had on my gpu and uninstalling MSI afterburner completely
None of that worked permanently, and it didn't always work for the short term either
When it happens:
Completely randomly and with different severities as mentioned earlier. It has only happened in a game twice, and both of those times was on LoL which isn't very demanding at all and it hasn't happened on BF3 yet (haven't played it too much yet, only a few hours compared to playing a lot of LoL recently so games don't really seem to be an issue or a direct cause) which is also why I am relatively sure it is not a hardware problem. It has happened randomly just on the windows desktop, while browsing online, and on just about any other random task on the computer.
