DDR2/DDR3 compatibility issues PLZ HELP
Hi
i intend on buying a new graphic cards for my PC and DDR2/DDR3 has got me all confused PLZ HELP
COMPUTER SPECS:
Operating System
MS Windows XP Professional 32-bit SP2
CPU
Intel Core 2 Duo E4600 @ 2.40GHz
Conroe 65nm Technology
RAM
2.00 GB Single-Channel DDR2 @ 332MHz (5-5-5-15)
Motherboard
Intel Corporation D945GCNL (LGA 775)
Graphics
AL1916W (1440x900@60Hz)
Intel(R) 82945G Express Chipset Family
Hard Drives
244GB Seagate ST3250310AS (SATA)
Optical Drives
ASUS DRW-2014L1T
Audio
Realtek High Definition Audio
MY QUESTION
i intend on buying a DDR3 graphic card
but i dont know if it will be compatible with my motherboard...since i have a DDR2 RAM
PLZ HELP
2 answers Last reply
More about ddr2 ddr3 compatibility issues help
  1. it will work. gpu RAM is not related to the RAM being used by the mobo
  2. Renz496 is correct. Graphic memory has no relationship to system memory. You could install a graphic card with (G)DDR5 memory and it wouldn't cause any issues.
    -Wolf sends
Graphics Cards DDR2 DDR3 Compatibility Graphics
