[New] Will this power supply work?
4 answers Last reply
More about power supply work
  1. None of the links worked except the PSU. Not a high quality PSU and the label contradicts the rating from the mfr. It's sold as a 460W PSU, but the max combined voltage for the 3.3V, 5V, and 12V is 430W...definitely misleading labeling/marketing.
    With only 15A on 12V2, this PSU won't support many decent GPUs if the mfr has actually separated the the 12V1 and 12V2 rails. If you don't already own this PSU, then I would buy a different PSU. If you do own it, then I would still get a better quality PSU.
  2. Whatever you do, avoid that PSU. Very low quality. Try something like this: http://amzn.to/Kvv3Pu
  3. your GPU link does not work (as stated above)
    do you already own the apex PSU? if you are looking at a new PSU, i suggest the corsair 430w. that apex is a mediocre PSU on a good day.
  4. Is this your GPU?
    ASUS EAH6850 DC/2DIS/1GD5/V2 Radeon HD 6850 1GB
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121419
Power Supplies Build Components Product
