Hello, I recently decided to add a EVGA gtx 550 ti card into my Dell Inspiron 570. I put the card into the Pci Exress slot which was empty(came with integrated) and then I also switched my psu which was 300W to a 550 plus from Antec. I plugged in each wire including a 6 pin labeled "PCI Express" from my psu to my 550 ti. So I plugged everything back into my Inspiron and turned it on. My monitor noted that the vga plug was indeed connected into the computer but there was just a black screen, no bios, nothing.
I thought that perhaps some wires from my psu to my HD, mobo etc. were loose and opened up my case and made sure each wire was in place correctly.
When this did not work I decided to just take out my 550 ti gpu and also switch my new Antec 550 W with my old 300 W psu. When I did this my computer turned on normally no problems except for "recent changes" error message which was resolved by restarting my comp.
So, now I am confused as to why I got the blank screen. Was it the Antec psu or the new graphics card? Also my gpu has on the side 2 vga slots but I plugged my monitor to the vga slot on the back of my computer, like it always was. Myabe that had something to do with it? I dont know. HELP!!!!!
