Closed Solved
HELP GRAPHIC CARD FOR MY SYSTEM [HD5670 OR ELSE] ?
Hello, my PC spec is-
CPU- dual core 2ghz[2180]
RAM-2gb ddr2 ram[667mhz]
HARD DRIVE-250+160 GB[sata]
PSU- 450watt
OS-Win XP pro 32 bit
BOARD- Mercury mncp73v
[http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=766]
DISPLAY-dell lcd [e1609w] [1366x768] [16 inch]
So i am thinking to buy hd5670 ddr3 1gb
HD5670 DDR5 512MB not available in my area
and ddr5 1gb available but over my budget
HD5670 IS PCI Express 2.1 x16
I Think my board is PCI Express 1.1 x16
so this card will work ?
or anything else please suggest
i will buy from here
HIS AMD/ATI Radeon HD 5670 GPU 1024 GDDR3 Graphics Card (Radeon HD 5670 GPU)
http://www.flipkart.com/computers/components/graphics-card/his/itmd2ryn7mjh9pqd?pid=grcd2rynwcdczzqz&_l=QQvmX_tu6OkFNWFP5zMV6A--&_r=xJTm5aZ1YER0_as7fupvlA--&icmpid=reco_pp_personal_graphics_card_14
Zotac NVIDIA GeForce GT 440 1024 DDR3 Graphics Card (Geforce GT440)
http://www.flipkart.com/computers/components/graphics-card/zotac/itmd4uwpjbhfkddc?pid=grcd4rc6hgggqdvn&_l=pLe9R2JIOBc8D46SlrxtGg--&_r=ZWP_QZ7O7nzB4CHJxETJ8Q--
Zotac NVIDIA GeForce GT 240 1024 GDDR5 Graphics Card (GeForce GT240)
www.flipkart.com/computers/components/graphics-card/zotac/itmd4uwppzzh4huz?pid=grcd4rc6zs6ducmz&_l=pLe9R2JIOBc8D46SlrxtGg--&_r=ZWP_QZ7O7nzB4CHJxETJ8Q--
my budget is 4700 rupee[$89.77]
thanks
10 answers Last reply Best Answer
More about help graphic card system hd5670 else
  1. Do you have any plan to upgrade the whole system?
    not for now, maybe 1 or 2 year after
  3. I have heard that PCI-E 2.1 cards doesn't work with 1.1 or 1.0 slots, 2.0 does. So go with the one that has 2.0 (The nvidia card).
    thanks for info
    but is there any software to check motherboard PCI-E because i have still doubt on my motherboard
    so which nvidia will be better gt240 1gb ddr5 or gt440 ddr3 1gb
  5. I don't know any of them, the best way you will check is in the manufacturers' website. I think the best thing is to get nvidia, GT440.
    ok i will see nvidia gt440
    but i check web site and found XFX HD 5670 1024 DDR3 is also PCI-E 2.0
    but whithout fan
    here link http://www.flipkart.com/computers/components/graphics-card/xfx/itmd2ryn8gzymfsj?pid=grcd2rynm5fhkedq&_l=fw+oKmOSuCP0ATliBN8PQQ--&_r=D761cSeSOYH60Uwt_FeErQ--&icmpid=reco_pp_history_graphics_card_4
    so it will be gt440 vs xfx hd 5670
    what u think
  7. The card you want to upgrade to will be bottleneck by the processor. I would suggest go to save up and upgrade the whole system route. Because the card will not be fully utilized.
  8. Best answer
    5670 is faster and you are really smart there on looking PCI-E 2.0 cards :)
    I think it will run hotter but if you do not care about temperatures it's fine. You don't worry about bottlenecking much. These are low end parts so I think it will match up with the low end processor.
  9. Best answer selected by Ankki.
  10. Now, is it a success for you and you are happy :)?
Graphics Cards Geforce Graphics
