New system build advise
I am looking to build a new computer. This is my first time. I have spent a few weeks reading up and hope that I'm not missing anything. Please help out if you have the time.
Approximate Purchase Date:
the sooner the better OR wait until April for cheaper prices / better hardware (I would like to build soon; please advise if waiting until April will have big benefits)
Budget Range: 2,000 or less without monitor
System Usage from Most to Least Important: Gaming (Starcraft II, Diablo 3, and new games to come. I would like graphics that make me smile)
Parts Not Required: Mouse, speakers
Preferred Website(s) for Parts: newegg.com
Country: USA
Parts Preferences:
Mother board: ASRock Z68 Extreme7
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157269&Tpk=ASRock%20Z68%20Extreme7
GPU: 2 x Gigabyte Radeon HD 6950 1 GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125385
CPU: Core i5-2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Memory: Corsair CMZ8GX3M2A1600C8R DDR3-1600 C8, 4 GB x2 (8 GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233185&Tpk=Corsair%20CMZ8GX3M2A1600C8R
System Drive: SAMSUNG 830 Series MZ-7PC128D/AM 128GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147134
Storage Drive: Western Digital Caviar Green WD20EARS 2TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136514
Optical: Lite-On IHES208 8X (BlueRay read, DVD write)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106292
Case: Fractal Design Arc Midi OR Antec Three Hundred Illusion
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352007
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&Tpk=Antec%20Three%20Hundred%20Illusion
PSU: Mushkin Joule MKNPSJL1000
http://www.newegg.com/Product/Product.aspx?Item=N82E16817812012&Tpk=ushkin%20Joule%20MKNPSJL1000
Heat Sink: I want to spend about $35. What good ones are compatible with the CPU?
Sound Card: I want to use a sound card in the PCI that has a 1/4 inch stereo plug. I have no idea where to look for this. Pointing in the right direction would be great.
Keyboard: Logitech G510
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126100
Monitor: resolution 1920X1080 less than $300 dollars - I need help here.
Overclocking: Maybe in the future
SLI or Crossfire: Yes
Additional Comments: I'm not doing any overclock any time soon and I would like the system to not be super loud. If I overclock in the future, I can figure out how to address the noise issue.
I'm a super newb and want to build soon. Any advice would be used to maximize happiness in the world.
Thanks in advance.
8 answers Last reply
More about system build advise
  1. CPU COOLER : COOLER MASTER Hyper 212 EVO http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
    I recommend you Fractal Design Arc because if you have big video cards you can remove the HDD cage from the middle and after that the bigest GPU wil fit in your case.
    From the beggining buy one video card AMD 7950 or 7970 , with these you can play all games with a big smile. At this moment are the best. And if you need in the future you can add another one. Both of them can be overclocked verry well.
    SAPPHIRE Radeon HD 7950 3GB 384-bit http://www.newegg.com/Product/Product.aspx?Item=N82E16814102962
    This with better cooling SAPPHIRE Radeon HD 7950 3GB 384-bit http://www.newegg.com/Product/Product.aspx?Item=N82E16814102963
    HIS Radeon HD 7970 3GB 384-bit http://www.newegg.com/Product/Product.aspx?Item=N82E16814161399
  2. ASUS has the best z68 motherboards at this time.
    The power supply is just OK quality, and way overkill. More watts do not equal better quality. This one is better quality and will still be more than enough to do dual 6950 cards. http://www.newegg.com/Product/Product.aspx?Item=N82E16817207015
    Skip the sound card and get an adapter. http://www.newegg.com/Product/Product.aspx?Item=N82E16882125481
    The stock heat sink/fan will be fine for now. When you get ready to overclock, here is a good CPU Cooler - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
    For the monitor, you really need to go look at those in person. The one your eyes like is the one you buy. You can still get it online if it's a better price. Most folks these days go with 23" LED. ASUS is very popular in monitor's also although I prefer Samsung.
  3. Based on your advice I am changing:
    Mother board: Asus P8Z68 Deluxe
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131791
    GPU: SAPPHIRE Radeon HD 7950 3GB 384-bit
    PSU: XFX Core Edition PRO750W
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207015&Tpk=XFX%20Core%20Edition%20PRO750W
    I'm kind of bumping this as well. Any other advice?
  4. Yeah the one powerful card over two smaller cards is great advice. Maybe consider the 7970 and sacrifice a little off some other component. That Hyper 212 EVO is a good cheap cooler, everyones mentioning it.
  5. Any of these other boards would probably just work as well for you. http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=280&Description=&Type=&N=100006519+50001315+40000280+600158412&IsNodeId=1&IsPowerSearch=1&srchInDesc=&MinPrice=&MaxPrice=&OEMMark=N&Manufactory=1315&PropertyCodeValue=717%3A140053&PropertyCodeValue=20267%3A164178&PropertyCodeValue=20267%3A164177
    One word of caution on the 7000 series cards. If you still play any older DX9 games, the new cards seem to have a bit of performance trouble. this may or may not be fixed with future BIOS and driver upgrades.
    Other than that, I think you've got it.
  6. tlmck
    I am very much about backward compatibility for games. I still play Neverwinter Nights 1, Baldur's Gate, Diablo 1, Starcraft 1 and a lot of old games. I don't mind if these games don't have really high performance, but I would like them to be run decently. Do you know what I should expect? I was mad when I couldn't install Red alert on XP LOLZ!
  7. Look for Tom's recent review of the 7970 and 7950 cards. They show some older games with issues, but not as old as some of yours. you can also Google search the card number and DX9 to see more.
    I only had a AMD 6670 card before my current 550Ti, but never had any issues on even some old 2002 era games, other than a few that ran at about 500fps! :)
  8. Thanks to everyone for the conversation. I think I'm settled on getting my parts. Keep on rocking.
Build Systems
