First time building custom PC-HELP!
Will this specification for a custom build work?
I'm building a budget desktop gaming pc from scratch. Will these components work together? Any recommendations that will cost me up to £460? Here are the specs:
Novatech Prowler Midi Case V2
£30
Powercool 450W 80+ Dual 12v V2.2 High Efficiency Black Power Supply¬¬¬¬
£32
2nd Generation Intel® Core™ i3 2120 3.3GHz Socket LGA1155 - Retail.
£89
Asus P8H61-M LE/USB3 Motherboard
£52
XFX AMD Radeon HD 6770 1024MB GDDR5
£70
LG GH22NS70 22x DVD+/-RW SATA Black - Retail Boxed
£15
Seagate 250GB Barracuda Hard Drive - 3.5" SATA-II - 7200RPM 8MB Cache – OEM
£60
Corsair CMV4GX3M2A1333C9 2 x 2GB DDR3 SDRAM Memory
£17
Windows 7 Home Premium-OEM
£70
Total of £435
Budget is £460
Any help is much appreciated.
5 answers Last reply
More about first time building custom help
  1. fist of all stop being such a huge ******, second of all you can get more than 4 gb for ~£10 more, third choose a better PSU, fourth your HDD is overpriced, fifth uATX? really?
  2. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  3. firstly dont use fowl language. It makes you look unintelligent and ill-tempered and yeah it is my first time in building a computer-please respect that fact. secondly i dont need 8GB and when i do ill buy it. Thirdly, i dont need any more than 450W, fourth, i meant 500GB, fifth, ive changed it to an atx now
  4. 450W will not run your system well.
    Straight from the AMD page:
    450 Watt or greater power supply with one 75W 6-pin PCI Express® power connectors recommended
    http://www.amd.com/us/products/desktop/graphics/amd-radeon-hd-6000/hd-6770/Pages/amd-radeon-hd-6770-overview.aspx#3
    You are cutting it super close. It is best to have a 100W leeway on the PSU. I recommend a 550W PSU from Corsair, Antec, or XFX.
New Build Systems Product
