I've decided on building a custom gaming PC in the coming months and these are the components that i have chosen, this is my first PC build and i wanted advice on the components; if they are suitable to use.. i was also wondering if there are any components that i have missed out, also if you could recommend some better components that would be awesome, I don't really want to over spend on the PC so could you recommend components or product that are not super expensive I have a budget of around £1000 and willing to go slightly higher plus, I don't really want all the products to be high end, just enough to run games smoothly and also to be future proof
This is my list
PCU : XFX ProSeries Core Edition Full Wired 750W 20+4-pin ATX Power Supply w/SATA, PCIe & SLI Ready
Motherboard : Gigabyte Z68X-UD3H-B3 or GIGABYTE GA-Z68A-D3H-B3 Intel Z68 SLI/CrossFireX Socket 1155 ATX Motherboard w/HDMI, DVI, Video, GbLAN & RAID hmm
Harddrive(s) : Kingston SSDNow V+200 120GB SATA/600 2.5" Solid State Drive (SSD)
Western Digital 1000GB 7200rpm SATA
RAM : Kingston KTD-PE313/8G 8GB DIMM 240-pin DDR3 1333MHz / PC3-10600 Registered ECC Memory for Dell PowerEdge X2 or 4 Sticks
CPU: Intel Core i5 2500 3.3GHz (6MB L3 Cache) Socket 1155 Quad-Core CPU
Graphics Card : Nvidia GTX 570
Heatsink/Fan: Antec PRO 120mm Dual Ball Bearing Fan
OS : Windows 7 home premium 64 bit
DVD RW : Sony 24x DVD RW
PCI : Linksys Wireless-N PCI Adapter Network adapter
Thanks in advance for any help/advice
This is my list
