Sign-in / Sign-up
RAM problem
  • RAM
  • Intel
  • Components
Last response: in Components
June 7, 2012 11:56:59 AM
Hi
Yesterday I recevied my new system.
Intel Spur Lake Z77
Intel Core i5 3550
Nvidia GTX 550ti
Kingston Hyperx 1600mhz DDR3
Now my problem is that my bios won't adjust the RAM to 1600 but keeps it at 1333mhz.
Please help.
PS: Running win 7 pro 64x
Thanks
More about : ram problem
June 7, 2012 12:11:39 PM
Enable XMP profiles in the BIOS. Save and exit. Go back into the BIOS and you should see the change reflected there as well as any tool you use in Windows displaying the RAM speed.
m
l
June 7, 2012 12:22:03 PM
Where do I get the XMP profiles? I've basicly been through the whole BIOS.
m
l
June 7, 2012 12:34:03 PM
Under the Performance->Memory Overides->Performance Memory Profiles, choose Profile 1 for your XMP profile.
That should get the RAM to the 1600 speed if it's XMP enabled RAM. If not, you'll have to go to the RAM manufacturers site or contact them directly to manually set the voltages and timings.
m
l
June 7, 2012 12:48:34 PM
Isn't this gonna hurt my warranty. And what about stability. Some boards see this as overclocking. I dont want to oc since my previous motherboard's BIOS got burned that way
m
l
June 7, 2012 1:17:59 PM
I don't think so as 1600 speed RAM is supposed to be supported by the i5 3550 and you aren't changing the bus speed of the processor:
http://ark.intel.com/products/65516/Intel-Core-i5-3550-...(6M-Cache-up-to-3_70-GHz)
Contact Intel support to be sure of this one and post back here. This will be information we all could use.
m
l
