Solved
$700-800 or Less gaming system (I need help!)
  • New Build
  • Gaming
  • Systems
  • Product
Last response: in Systems
February 21, 2012 12:28:12 AM
Hey!, I'm in need of some advice and tips. I'm considering building myself a gaming computer for between about 700-800$ range(or less). And I need some suggestions and help on a few parts.
(Note: I DON'T need to be running Battlefield 3 on Ultra settings at 1080p with 120fps, i just wanted a gaming system that can run games such as minecraft, mw2, mw3, battlefield, all at about 1080p with a good solid fps.
So far i have picked out a:
case (if you can find a nicer one, for a lower price, please let me know)
cpu
ram
powersupply
and fan controller
let me know if you can find any of these for cheaper or if you can recommend something better for the same or lower price.
I need help picking out a:
graphics card (im thinking like a AMD radeon 6000 series card, and i need high deffinition ports)
motherboard
(*note i know like hardly anything about good motherboards)
aftermarket cpu cooler (for when i overclock it)
anyways here are the parts I've found so far:
Raidmax Blade Case
NZXT Sentry LX High Performance Fan Controller
Corsair Vengeance Desktop Memory Kit - 8GB (2x 4GB)
Intel Core i5-2500K Processor
Ultra LSP750 750-Watt Power Supply
More about : 700 800 gaming system
February 21, 2012 12:38:43 AM
Thanks for the reply, personally I didn't think the i5 was to overboard, but then again, I'm a newbie to the computer world, and the fan controller I personally like because of it's flashiness, it makes a statement which is kind of my personality, but If i have to sacrifice it for another part, I'll consider the one you suggested, thank you.
m
l
Best solution
February 21, 2012 12:39:18 AM
cpu
ram
powersupply
and fan controller
motherboard
Raidmax Blade Case
Here, try this -
SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
- Popular, lots of good reviews
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- Great one for overclocking, uppgradable to ivy bridge, easy overclocking.
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
- Basically the one everyone uses, works great
Not sure about that psu, defenitly dont skimp on it. Look for a good brand name one, like corsair or seasonic.
Maybe like this -
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
For the case, there are several that are great in that budget.
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
or
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case (love it)
Hope it helps!
February 21, 2012 12:46:26 AM
justdoit said:
Here, try this -
Maybe like this -
or
Hope it helps!
Thank you those look like some pretty budget friendly suggestions, and I've bookmarked a couple of them thanks!
m
l
February 21, 2012 10:58:18 PM
Best answer selected by Am_Hawk.
m
l
