Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Strange Graphics Card Issue
Forum Graphics & Displays : Graphics Cards Strange Graphics Card Issue
I have an Nvidia GTX 560 Ti. Lately whenever i boot up my computer, the graphics card has extremely low performance, not even letting me launch most 3D games. The performance is so terrible that it is almost unusable for any type of gaming. The first time this happened I downloaded and installed the newest Nvidia drivers which seemed to fix the issue. However upon restarting the computer was having the same issue. What is strange however is, though the latest drivers are installed, if i Re-install them the problem goes away again until the computer is restarted. I'm pretty sure the drivers installed properly because the Nvidia scanner recognizes that i have all the latest drivers installed. Though reinstalling the drivers every time I start the computer works it is getting a bit annoying and is a waste of time and I'm wondering if anyone can help with a more permanent solution, Thanks!
Specs:
Motherboard: Asus P8Z68 DELUXE/GEN3
Video Card: Nvidia GeForce GTX 560 Ti
RAM: 8Gb DDR3
Processor: Intel Core i5-2500@3.3GHz
Windows 7 64 bit
Reply to NickToll
I would uninstall all nvidia drivers, shut down, remove the card, reboot, then install the drivers for the integrated graphics. Then reboot, and repeat the process but with the discrete video card the 2nd time around.
Out of curiosity, what PSU do you have to power your system?
Reply to MarkusAurileus
Try using something like this tool to make sure all traces of the old driver are removed:
http://www.guru3d.com/category/driversweeper/
Reply to ringzero
guru3d has long since stopped hosting Driver Sweeper. Now its over on.
http://phyxion.net/item/driver-sweeper-290.html
To use this software, you want to uninstall the current drivers with the Add/Remove option in the control panel.
Once you have uninstalled, then use driver sweeper and then install the latest drivers.
Reboot between each step.
Message edited by nukemaster on 12-22-2011 at 11:55:18 PM
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/yfmxdc9 - Part Guide? http://tinyurl.com/5zk6me - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yjldsrw - No Boot?
Reply to nukemaster
Its an antec EA 750
Reply to NickToll
There are 2101 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bottlenecking?? What is it?
By horaciopz, 42 minutes ago:
This is an excellent explanation. this video will explain more graphically how...
Best offers
Top experts
