My new HD6850 graphic card makes my sound not to work
I just bought a 6850 card and when I installed it my sound card crashed. It says its found in the deveice manager, but on the icon beside the clock I have a red cross over the speaker icon and it says "no speakers or headphones are plugged in". When I run dxdiag it says it does not found any installed sound card.
I tried my old grahpic card and then the sound works
PLEASE HELP
I have a HP XW8600 the sound card is realtek and I have all the latest driver.
2 answers Last reply
More about hd6850 graphic card makes sound work
  1. Problem solved - Grahpiccards sound took over the internal one, I activated the onboard sound in bios instead of having it on automatic
  2. Good Just when you thought you have a nasty GPU and wow you fix it nothing better than that except using it. Good luck
Graphics Cards Speakers Sound Cards Graphics
