Hello Experts!
How does this build look to the Tom's Hardware Pros?
If you guys could check over my parts list I would REALLY appreciate it... and Thank You Much.
This is an under a $1000 Build.
Do I need to add a 200mm or two 120mm top fan(s)?
Or... Any other fan assemblies?
Does anything else catch your eye or need tweaking?
Case - COOLER MASTER HAF 912 RC-912-KKN1 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Processor - Intel Core i5-2500K Sandy Bridge 3.3GHz - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Motherboard - GIGABYTE GA-Z68XP-UD3 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128512
Video Card - GIGABYTE GV-N560UD-1G GeForce GTX 560 Ti - http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
Heat Sink/Fan - COOLER MASTER Hyper 212 Plus - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Power Supply - CORSAIR Enthusiast TX750 V2 750W 80 PLUS BRONZE - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
HDD - Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
Optical Drive - LG 22X Super-Multi DVD Burner - http://www.newegg.com/Product/Product.aspx?Item=N82E16827136240
Wireless Adapter - Rosewill RNX-N180UBE Wireless Adapter IEEE 802.11b/g/n USB 2.0 - http://www.newegg.com/Product/Product.aspx?Item=N82E16833166056
A SSD will come later. I am at my budget and want a large capacity [128Gb) SSD.
I have an LG 21" HD Monitor
Windows 7 Ultimate 64bit
THANK You!
THANK You!
