Hello everyone,
I recently purchased this card and installed it into my system on Monday: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
Since I've installed it, I've been having a reoccurring problem with it. This is the first video I've bought that I've had problems with so I admit I do not have the skills to simply understand why this is happening.
Usually, while I am playing Garry's Mod/Minecraft and am speaking on Ventrilo, my computer will randomly start acting up. According to my On-Screen Displays and the EVGA Easy Precision tool, my GPU usage drops to 0-1% and its temperature returns to idle, while my CPU feels as sluggish as if it was at 100%. If I recall right, when I was once able to get task manager open while this occurring, it said my CPU usage was up to +90%. My entire system lags and I am unable to hardly do anything for 5-10 minutes. If I wait it out, the system recovers. However, just as I was writing this thread, my computer had it happen twice, only a few minutes apart. A third time while playing Garry's Mod just before starting to write this thread. That means 3 times in a row, only 5-15 minutes apart.
I have no idea why this is happening, and don't really know what else to look for. It first started while I was using FurMark within a few hours of installing this card on Monday and was slowly OC'ing it. With my core clock up to about 920, after about 5 minutes of FurMark, the system lagged out, and I was forced to slowly shut off FurMark, which seemed to fix it. Ever since then, the problem has been occurring randomly each day.
I tried using different drivers, version 275, still happened (was using 290 beta).
I returned my OC settings back to stock, still happened.
I switched my Power Management Mode under the NVIDIA panel to "Prefer Maximum Performance" as suggested by a friend, still happened.
I increased the voltage from stock 1.012 to anywhere between 1.063, still happened.
I reseated everything on my motherboard and cleaned out any dust, still happened.
I even tried using only one monitor to see if somehow having overlapping displays was causing problems, still happened.
I have no experience with this so I am sorry if this is a cut-and-dry problem that someone would be able to identify automatically. I just don't know what else to do.
Specs:
Mobo: ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX
CPU: AMD Phenom II X6 1055T Thuban 2.8GHz OC'd to 3.5Ghz
PSU: SeaSonic M12II 620 Bronze 620W 620w, 500 minimum required on this card
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 4 Sticks = 8GB RAM
Specs:
