Help Me for Motherboard & Memory for overclock system
Last response: in Systems
Hi every one
I am half way to go for new system.
I GOT: CPU (I5-2500k)/ Intel 160 SSD+WD-1T black/ XFX Radeon HD 6870 Dual Fan/ Antec neo 600W PS/MASTER Hyper 212 EVO
This system I will build it for my Son he can play the latest game.
Som one advice me to get this main board GA-Z68XP-UD3P ($189)
I look at GB web for memory I can not find any memory list for 16G 2x8 for this board.
I need some help to get memory good for overclock with this board GA-Z68XP-UD3P, or another board better than this for overclock.
Also I looking for the case with front USB3 under $100.
Please help
well if you get the asus maximus IV extreme-z z68 ROG board it has an option that oc's your cpu to 4.6 and adjusts all the voltages youd need to adjust in just a 2 or 3 clicks and the g.skill ripjaws x series 8gb 1600 mhz is good ram
I have the UD3P and it's been an excellent board so far.
The problem with the aforementioned Maximus IV is that it's a micro ATX board and it will severely limit your long-term expansion options. It's a good board but I really hesitate to recommend it for that reason.
Man this board cost too much $389
Related ressources
I think this is the one he's referring to: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
But if it's this one: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - yeah that is too much money. :ouch:
I'd stick with the Gigabyte personally - I don't like Micro ATX just for the limited expansion options. One of these would be far better choices:
- Gigabyte GA-Z68XP-UD3P: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
- Asus P8Z68-V Deluxe: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Quote:
Is this mother boad easy to overclock?
It's fairly easy - Gigabyte includes a utility called "TouchBIOS" which is a hybrid UEFI interface that allows you to tweak the BIOS from Windows.
Quote:
which memory work good for overclock with this board?
This is one of the best overall brands on the market for RAM - I've used plenty of theirs and had 0 issues with it:
The only thing is when you do overclock - be sure to set your RAM speeds to stock and do not go over - if you overclock your RAM beyond the maximum speed it can handle or set your memory multipliers and voltage beyond what it can handle that has the potential to be very dangerous, like fry your whole system bad. Tread very carefully when you overclock.
Quote:
Do I need 16G memory or 8G memory that good enough?
Depends on what your primary use is - if you're going to be using it for gaming 8GB is plenty. If you're going to be using, say, After Effects or any video editing and rendering software, you'll need at least 16GB. The Gigabyte UD3P supports up to 32GB with the latest BIOS (F6).
Thank You So much for your help.
Do you know any web with tutorial show how to set up for overclock?
Ask the community
