Solved
Building New System With AMD fx 6100
Last response: in Components
June 9, 2012 7:34:10 PM
Hello,
I'm building a new desktop...I'm a gamer and right now i'm tight on budget....The hard disk i'll using would be from my old desktop...The processor which i have chosen is AMD fx 6100..
I don't have much knowledge about Motherboards, Graphics Cards and PSU...So need suggestions regarding these three products..
My last two motherboard were dead due to heat problem, so now i want to build a system which is good in performance and reliability..I'm not into stuff of over-clocking.
June 9, 2012 7:40:34 PM
I have the AMD FX 6100 and I was disappointed with the gaming performance! It has weak per core performance and I had better performance in games with my Core 2 Duo @ 2.33GHz to my surprise. I would recommend going with Intel, but if you want an AMD system go for the older Phenom II range a lot better and cheaper with none of this integer core rubbish!
m
l
June 9, 2012 7:43:58 PM
I have "AMD 3.4 GHz AM3 Phenom II 965" in my mind
m
l
a b À AMD
a c 87 V Motherboard
June 9, 2012 8:02:00 PM
dstubbornkanav said:
I have the same in my mind with ASUS Sabertooth 990fx motherboard...What about PSU and GPU?
what's your budget then i can recommend something
m
l
June 9, 2012 8:08:28 PM
bigcyco1 said:
I would get this AMD CPU http://www.newegg.com/Product/Product.aspx?Item=N82E168... otherwise i go intel
Its approximately Rs 25000 that's around $ 460-470 for mobo+processor+PSU+GPU...If money is an issue, then i can buy GPU after sometime as well...I just want something best in performance and reliability
m
l
June 9, 2012 8:14:15 PM
Approximate Purchase Date: this week
Budget Range : Rs 25000
System Usage from Most to Least Important:Gaming, Surfing and watching Movies
Parts Not Required:Hard Disk
Preferred Website(s) for Parts:flipkart.com
Country:India
Parts Preferences: Phenom II 965 with Asus Sabertooth 990fx
Overclocking: May be
SLI or Crossfire: No
Monitor Resolution:1280x1024
Additional Comments: Should be reliable
m
l
June 9, 2012 8:37:49 PM
bigcyco1 said:
If you can buy GPU later it be better otherwise all you could afford now is a 6850 http://www.newegg.com/Product/Product.aspx?Item=N82E168... and for PSU i get http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I have to order everything online, but I'm getting not this PSU in any of the famous Websites that delivers product in India...So, any other PSU you want to suggest?
And could you tell me is this the same Mobo that you have suggested:
http://www.flipkart.com/amd-3-4-ghz-am3-phenom-ii-965-p...
m
l
a b À AMD
June 9, 2012 9:08:18 PM
Thanks amuffin yes that power supply
m
l
a b À AMD
June 9, 2012 9:10:05 PM
that link takes me to a cpu not a motherboard and amuffin found you the PSU
m
l
June 10, 2012 10:10:21 AM
Phenom II X4 965 currently is out of stock...So should i go for 970 or 960T?
m
l
a b V Motherboard
June 10, 2012 11:06:14 AM
960t and unlock extra cores and or OC to 4.0ghz, but the 970 is nice also.
m
l
Best solution
a b V Motherboard
June 10, 2012 11:16:40 AM
June 11, 2012 8:08:46 PM
Best answer selected by dstubbornkanav.
m
l
