Closed Solved
Power Button Does Not Turn Machine Off? Turns on Though
power button does not turn pc off just restarts
3 answers Last reply Best Answer
More about power button turn machine turns though
  1. Best answer
    If its the power button on your pc that is not working correctly, I suggest unpluging the power button and turning it on manually.
    If that does not work and you get the same outcome, then its your either your power supply, or motherboard that is not working.
  2. The power button on the PC tower works when I hold for two seconds, That's OK.
    It's the "start" menu power button that acts like the restart button
  3. Best answer selected by artminchin.
New Build Power Systems
