What will happen if i replace power supply from 220 watts to 700 watts
Hello, what will happen if i replace the 220 watts power supply to 700 watts?
3 answers Last reply
More about what happen replace power supply watts watts
  1. Nothing really, it just gives you more wattage for a GPU, etc.
  2. The components still pull the same amount of power and the power draw from the wall is the same presuming that both PSU's have the same efficiency. The positive as above is that you now can start upgrading.
  3. it really only makes it so you can add better parts to you rcomputer later on.
Power Supplies Components
