Closed Solved
First System Build - Opinions/Advice
Approximate Purchase Date: within the next couple weeks.
Budget Range: $600-$800 after rebates
System Usage from Most to Least Important: swtor, tera, skyrim, internet surfing
Parts Not Required: monitor, keyboard, mouse, speakers, os
Preferred Website(s) for Parts: newegg
Country: United States
Parts Preferences: Reliable brands
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1440x900
Additional Comments: This is what I have so far as my wish list. Would appreciate any input on if this will be able to run swtor at max setting, can I downgrade any of this to save money or will I need better?
Current Wishlist: http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=70412682241511620120222122319
2 answers Last reply Best Answer
More about first system build opinions advice
  1. Best answer
    Your wishlist shows empty.
    At any rate, look for a i5-2400 CPU. Not overclockable, but only 10% slower at stock speed than the overclockable i5-2500k, and still plenty fast.
    A low end ASUS or Gigabyte z68 motherboard.
    2x4gb DDR3 1333 speed ram.
    An AMD 1gb 6870 video card.
    Western Digital SATA 6gb/s 500gb hard drive
    Samsung DVD RW.(around $17)
    Coolermaster HAF 912 case.
    SILVERSTONE ST50F-ES 500W power supply.
    These are best bang for the buck, and more than enough for your requirements.
  2. Best answer selected by ashram333.
New Build Systems
