Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > [Solved] Best budget gpu and power supply
Forum Systems : Homebuilt [Solved] Best budget gpu and power supply
Best answer from o1die.
Hello, building an i5 home[family pc] we play online games only[shockwave and roblox] heavy youtube and netflix. dont want to upgrade for a while, no overclocking....thanks
Reply to darz549
i had looked at the hd6850 and the 550ti
Reply to darz549
thanks 01die i had looked at this gpu and a 550ti,a lot of reviewers have complained of different power supplies squealing [noisy] i am newby just wanna get it right,and also if it says 600 watts does that mean only if it needs the power that it uses it, once again thanks
Reply to darz549
Tell us your budget & computer specs as well. If you don't have anything picked out yet - fill out the form.
http://www.tomshardware.com/forum/ [...] ild-advice
-Bruce
Message edited by dish_moose on 02-23-2012 at 04:24:48 AM
Reply to dish_moose
What kind of gaming performance are you looking for?. I would go with the 6850 over the 550 ti. What is your resolution?
Message edited by Anonymous on 02-23-2012 at 04:26:57 AM
Reply to Anonymous
parts list so far i have hp atx case with 2 cd dvd and 21 in monitor i do a lot of multitask research etc
CPU: Intel Core i5-2400 3.1GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock Z68 Extreme3 Gen3 ATX LGA1155 Motherboard ($129.86 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1333 Memory ($39.99 @ Newegg)
Hard Drive: Samsung Spinpoint F3 500GB 3.5" 7200RPM Internal Hard Drive ($88.99 @ SuperBiiz)
Hard Drive: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($117.11 @ CompUSA)
Video Card: EVGA GeForce GTX 550 Ti 1GB Video Card ($109.99 @ Newegg)
Power Supply: Corsair 430W ATX12V Power Supply ($36.98 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($99.99 @ Newegg)
Total: $772.90
Reply to darz549
Best answer
Corsair is a good brand, but I recommend 500 watts minimum. The rosewill I recommend has around 50 amps on the 12v rail, and good newegg reviews. If you want modular, you'll need to spend around $90 or more for a decent brand with 50 amps on the 12v rail, so the rosewill isn't a bad choice. If you can travel to a microcenter, you should be able to get a motherboard combo with the motherboard almost free after discounts. Talk to a store manager if the salesperson doesn't know what discounts are available.
Reply to o1die
hd 6850 and the gtx 560ti are both same different in price, but performance wise are very close, just get the 6850 and for the psu, get seasonic psu, a good seasonic 520e 80plus bronze is gonna be your best bet, but if you really want good psu go grab the seasonic x-1250w 80plus gold (assuming they still have that 15% off) as it would be cheaper than the 850w 80plus gold of seasonic
------------------------------ [Intel i7 3960X][Noctua NH-D14][MSi X79A-GD65 8D][Sapphire HD 7970 Dual X 3GB (X3)][G.SKILL Ripjaws Z 8X4GB 1600Mhz][SeasonicX-1250 80PLUS Gold][Cosmos II][Corsair Vengeance K90][Roccat Kone+][Roccat Alumnic]
Reply to Tavo_Nova
Take a look at this links:
http://www.newegg.com/Product/Prod [...] 6817159062
http://www.newegg.com/Product/Prod [...] 6814150540
Reply to aqe040466
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1485 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 4 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
