Help with first build plz!!!!!!!!!!
hi1234258
12
1.LG 22X Super-Multi DVD Burner 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model GH22NS90B - OEM
2.COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan
3.XFX HD-695X-ZNFC Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
4. ASUS P8Z68-V/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
5OCZ ZS Series 650W 80PLUS Bronze High Performance Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom
6.CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model CMX8GX3M2A1333C9
7. Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
8. Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
would all this work together like is the psu okay with the case and is the gpu and ram okay with the motherboard and is the motherboard okay with the case and what does it mean when a video card has 2gb do you guys recommend getting it?
illfindu
370
Okay let me try and run through you'r questions. First off i might be missing it but i don't even see a PSU here but almost any model would fit I have the haf 932 its huge it has allot of options and you can both top and bottom mount a PSU. You are gonna want at least 750 watt for a 6950 you could probably go a little lower but you will be limited in your upgrades. I just noticed your psu and yes that would probably just about work you wont have a issue but if you add more harddrives or a bigger or second gpu you would have to upgrade. The ram is fine but i would go for a set that's DDR3 1600. The GPU and RAM go fine with that board, the mother board fits in the case. Now in terms of the memory on the card its like the ram on your MB it basically only equals better performance at higher resolutions 1920x1080 and below you most likely wont see a difference between 1 gb and 2gb but after that you will see a FPS drop. When you get to like 2560x1600+ you kinda NEED 2gb or you will have to scale down settings.
hpdeskjet
458
Try this PSU:
XFX Core Edition PRO650W (P1-650S-NLB9) 650W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply $89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
Also get one of these if you plan to overclock down the road:
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 1366/1155 and AMD FM1/AM3+ $34.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7 $27.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Here is a relevant thread for helping you decide on what RAM you want to get:
http://www.tomshardware.com/forum/333313-31-intel-speeds
illfindu
370
It means the ram runs a bit faster its not a huge difference but the price in some cases is almost the same and newf is right in MOST cases when ram runs at 1.65 its actually overclocked at the factory which gives you LESS head room to overclock for instance some 1600 ram is just 1333 ram ran at 1600
Newf
2,010
The 1600 is just a little better (faster at the same voltage) than 1333.
Yes. The issue for me is the voltage.
Intel 1155s work best when the voltage is not pushed. Don't burn out the cpu...
Higher volts are ok for AMD.
If you bought 1333 ram that would be fine also.
The 1600 ram does give you more headroom, and the cost is basically free.
If you go to Newegg and power search desktop memory, check ddr3, 1.5 volts, 2x4GB, 1600 speed and the 3 variants of 1333.
Lots of sticks for $36-$45.
hi1234258
12
O do you think with what i have it would be ok to upgrade to ocz 700wpsu instead and 1 tb hardrive and 2sets(16gb) of ram you suggested? and could i get the 16gb of rams i was talking about but not upgrade psu and just stay with 650w?
Newf
2,010
The 650 watt psu you originally listed is fine UNLESS you want to add another video card later.
Then you would need a supply that has 4 6-pin (or 4 6+2 pin) connectors.
These typically start at a minimum of 750 watts.
