Solved
Is it ok to splice sata power cables to extend them
We have a new power supply for my sons PC. The power connector on the new supply is a straight one,we need it to be 90*. Can I cut and splice the old 90* connector onto the new supply cable harness?
7 answers Last reply Best Answer
More about splice sata power cables extend them
  1. you can, I assume you are soldering and using heat shrink over the joints, and talking about the 20/24pin connector?
    you might be able to find a 24pin to 24pin connector. http://www.ebay.co.uk/itm/24PIN-TI-24pin-90-Degree-right-angle-Extension-18-/130511942718
    I'm sorry I should have been a little more specific, I need the connector that powers the hard drive to be 90*
  3. I'm sorry I should have been a little more specific, I need the connector that powers the hard drive to be 90*.
    I assume it's still ok ( yes I will solder and heat shrink the connections). Is that correct.
  4. Best answer
    Ah, I suppose you can splice them too, but you can also buy converters for them too:
    http://www.servercase.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Molex-2xSata-power90&Category_Code=Cables
    I've seen power extension cables with right angles on the end too.
    This might be easier than 'splicing'
    http://www.kustompcs.co.uk/acatalog/info_1950.html
  5. +1 for punchdown connectors
    Might want to take a look at the old psu, it may have them
  6. Thank you
  7. Best answer selected by ejcoop9.
Power Supplies Power Cable Components
